Ok, done with the in tank pump. Come in.
cool, ive been wondering about a fuel pump upgrade.
where'd you get the pump from?
i guess this pump's supposed to be daily driver reliable too?
it came w/ everything you needed to put it in?
ive got to agree w/ Wilde though, pulling the bed off is easier. CHIP
Tin Foil Hat Wearin' Fool
Pulled the bed off to change out the sending unit in my truck. 6 bolts and unplug the connector for all the lights and the filler neck and its off. Will a 255lph pump be enough for a 408 and a 250 shot of nitrous? I know Im going to have to upgrade for my new setup but dont know exactly how big Im going to have to go.
How do I change this text
Not sure for the pump, but I'd check into a dual set-up like parish has got. Then you know you won't have any fuel pressure problems. my .02$
One thing I noticed with my fuel pump is when the tank is under 1/4 full, and I get on it hard, my fuel pressure drops off and I get a missfire code. Not good for the fuel pump or the engine.
Have you logged the fuel pressure at different points(idle, wot,etc)? I'd like to see if it stays pretty much where its supposed to. My buddy did an inline on his dodge, and he was getting way too much pressure and I believe some vapor lock to boot. Just want to make sure everything is good before the purchase.
Well I dont really believe in inline pumps due to the fact that you are limited to the flow of the intank pump, correct me if I'm wrong but if your intank flows lets say 100l and you have a 255l in line the how the hell is it pumping 255? I may not understand the whole thing but it seems logical.
