Ok, gentlemen, with the new motor due to be in pretty soon, trying to find a tranny
Old 07-27-2004 | 03:44 PM
greentahoe's Avatar
Originally Posted by kickassT/A
i think the trucks use a different input shaft than the f bodies. don't quote me on that
Im pretty sure they are interchangable. Scream swapped an LS1 into his truck and I believe he said the tranny bolted right up. Of course, Im not exactly a mechanical guru either
Old 07-27-2004 | 04:32 PM
zippy's Avatar
i most certainly wouldn't use that. i'd recomend getting the gm 4L65E over that any day or a stock standard model. not impressed at all with that.
Old 07-27-2004 | 05:08 PM
TeamTripp's Avatar
Its not a "truck -vs- F-body" debate when it comes to input shafts, its "GenI/GenII -vs- GenIII"
Trucks and F-bodies w/ the GenIII engines (4.8, 5.3, 5.7 and 6.0) use an input shaft thats wider at the top, a 300mm converter, longer stator shaft and a specific bellhousing.
Trucks and F-bodies w/ GenI/GenII engines (4.3, 5.0, 5.7-R/P) use the older input shaft, 298mm converter, shorter stator shaft, and a different bellhousing then the GenIII
Old 07-27-2004 | 07:34 PM
sry for the misinformation. i thought thats what mike kurtz at century told me when my tranny took a **** and i had a 4l60e out of a truck in my garage. he told me the vettes and the trucks had a different input than the f bodies.
Old 07-27-2004 | 08:47 PM
TeamTripp's Avatar
'98 and later trucks had the 2-piece case like the LS1 cars, but if it came with a 4.3L, 5.0L or 5.7L (VIN R), then it had the older "small tip" input shaft and won't work, so he is right. But if its a '99 or later (which was when the GenIII engines were offered in the trucks) and has the 4.8L, 5.3L or 6.0L, then yes, it will work.
BIGD4504
07-28-2015 11:46 AM
chacho44
14
07-25-2015 01:47 PM
jmarkway
07-18-2015 09:23 PM
JordanH
07-14-2015 03:46 PM
abey15
07-13-2015 02:20 PM
Quick Reply: Ok, gentlemen, with the new motor due to be in pretty soon, trying to find a tranny
