ok what do yall think of my parts list for my new tranny
this is my list of goodies i plan to get or already have id like yalls thoughts on my stuff ive looked into gettin and etc...
Sonnax intermediate servo release check valve(slready have)
29 element borg warner forward input sprag
low / reverse spring and roller
Alto carbon fiber band w/Extreme Duty band drum
Z-pak
4th gear servo (already installed)
Corvette servo (already installed)
Ac delco 5 pinon rear planet (already have)
Ac delco 5 pinon front planet(already have)
Sonnax oversized sungear bushing
Sonnax oversized rear stator bushing
Sonnax oversized casing bushing
H/O pump slide spring (already have it)
Harden Output shaft
Extream Duty Reaction Carrier Shaft with Beast sun shell
Extream Duty harden input shaft and drum
New spring kit
New piston set
Brand new and complete Electronic kit
Sonnax Pinless Forward Accumlator piston (already installed)
Sonnax Pinless 1-2, 3-4 Accumulator Piston (already installed but only in 3-4)
Sonnax solenoid snout (already installed)
Transgo hd shift kit, one washer to be used (already installed)
Ls1 Flywheel
Z-pak
Harden Output shaft
New spring kit
New piston set
Ls1 Flywheel
It all looks good, I just finished installing most of that in my transmission.
https://ls1tech.com/forums/showthread.php?t=331538
https://ls1tech.com/forums/showthread.php?t=326124
note
-High volume pump rotor kit (13vane)
you already have this from the factory
- Extream Duty Reaction Carrier Shaft with Beast sun shell
Again the factory trans uses a bearing not a thrust washer. But this part may be stronger, I don't know. Also the Torque drive kit comes with a hardened beast sun shell.
note
5.3Caprice
11-07-2015 08:56 PM
05GMC4.8
08-07-2015 09:55 PM
