Okey Dokey! Got 215/215 cam in
Old 07-10-2003, 07:02 PM
  #21
11 Second Club
Default Re: Okey Dokey! Got 215/215 cam in
are these numbers through the exhaust or thru cutout.
Old 07-10-2003, 07:16 PM
  #22
The numbers are right. It was through a cutout right after the stock ypipe, cats and manifolds.
Here's the dyno graph.
http://64.49.232.188/images/products/rms/RMStruckcam
Old 07-10-2003, 08:47 PM
  #23
BigTex's Avatar
Its interesting that the torque peak moved up about 1000 rpms. How do the very low rpms feel (1000 - 2000)?
How many rpms are you planning on spinning that thing? It looks like it will pull pretty well to the mid 6Ks.
Time for a set of headers.
Old 07-11-2003, 12:23 AM
  #24
gonzo 6.2's Avatar
Hey Tex, How much did your peak move up with the Ls6 cam?
Old 07-11-2003, 06:51 AM
  #25
BigTex's Avatar
My peak did move up, but my dyno doesn't show the lower rpms. Peak HP looks to be in the 5700 rpms area. I cant tell where peak torque was because its so flat. The LS6s large split and 116 LSA really stretched out the curves.
2001 LS6 cam dyno
Old 07-11-2003, 07:54 AM
  #26
1BADHD's Avatar
So......does does this look like a cam for a 5800+ lb truck, daily driven and tows 5000+ lbs every other weekend!
Old 07-11-2003, 08:53 AM
  #27
It feels like it did before the cam swap from 1000rpm to 4200rpm....after that it comes on real strong. It could really use a little higher idle and a 6500 rev limiter and 6400 shiftpoints.
I don't think it would be a good cam for big truck.
Old 07-11-2003, 08:57 AM
  #28
1BADHD's Avatar
Do you have any suggestions of what would be?
Old 07-11-2003, 09:04 AM
  #29
A 2002 Ls6 cam or a smaller comp traditional split.
We ended up with 322rwhp and 313rwtq last night after playing with the MAFT.
Old 07-11-2003, 09:09 AM
  #30
BigTex's Avatar
1BADHD - How about a custom comp cam 208 212 114LSA .554 .558 +4 advance. Should move the peak down and with 10 degrees less total duration, the low end should be good.
Quick Reply: Okey Dokey! Got 215/215 cam in
