Okey Dokey! Got 215/215 cam in
#22
Re: Okey Dokey! Got 215/215 cam in
The numbers are right. It was through a cutout right after the stock ypipe, cats and manifolds.
Here's the dyno graph.
http://64.49.232.188/images/products/rms/RMStruckcam
#23
Its interesting that the torque peak moved up about 1000 rpms. How do the very low rpms feel (1000 - 2000)?
How many rpms are you planning on spinning that thing? It looks like it will pull pretty well to the mid 6Ks.
Time for a set of headers.
#25
My peak did move up, but my dyno doesn't show the lower rpms. Peak HP looks to be in the 5700 rpms area. I cant tell where peak torque was because its so flat. The LS6s large split and 116 LSA really stretched out the curves.
2001 LS6 cam dyno
2001 LS6 cam dyno
#27
It feels like it did before the cam swap from 1000rpm to 4200rpm....after that it comes on real strong. It could really use a little higher idle and a 6500 rev limiter and 6400 shiftpoints.
I don't think it would be a good cam for big truck.
