Operation hell blazer....
#31
Stock HD 6.0 truck and van oil cooler lines for the 35" radiator. Also found on various Cadillacs.
http://www.midwayautosupply.com/p-50...on-2002-0.aspx
#32
Custm2500's Rude Friend
#33
I understand the need for more power, But I can't see the extra cost for the 408 for a daily driver... You don't think a fresh 6.0 with Flat tops, a nice cam and a stall will be enough??? Not trying to Bash but Just curious. Either way I feel real bad for that poor transmission....
#35
Because the wife wont let me supercharge it. Hard to justify a two part purchase. I did this because I want our truck to have the CID I want. I, later, then can go back in with such item later and be ahead of the game.
This thing is a mild 408. It should be putting down upper 300's rwhp. Nothing insane. I can't believe some of the reponces. LOL I can do this and stay on budget. I have been building stuff like this for years and have enough laying around. Gas is no issue as it is around town driver only. Once you hook a load to it anyways MPG goes right out the window. A nice large cube NA setup is a more reliable setup than any FI anyways.
#36
I disagree. A Radix or TVS bolted onto a factory-built stock motor will be much more reliable than any aftermarket motor. Start introducing multiple variables into an engine build and the likelihood of problems increases very quickly.
#37
Talking of multiple variable, a super charger brings more of them to the table.
#38
This is true to an extent but if you've ever heard of "Blueprinting and balancing" a motor thats how you make them live compared to just throwing them together and trying to achieve as much as possible "while cutting corners"
#39
As I said I wasn't trying to bash your idea, I was just curious why the need to spend the extra coin on the stroker part of it. I Personaly believe you can acheive the same overall goal with out the need to build a stroker.... I don't think you need FI either.... a stock 6.0 should already be close to 300RWHP
If you do build the a stroker DD moter I would like to see what you come up with and the end result when it's finished.
Good luck either way!!!
#40
I dailly drive my 850 rwhp TA. It puts down 555rwhp 506 rwtq NA. The only problem I have had with it is stupid stuff. Engine runs like a top on 91 octane. Did those #'s a=on 91 too. (116 octane is sprayed with the shot)
