Original Crank Pulley Shaking/Wobbling...Help
Will the replacment of an ASP fix it? What would cause the pulley to shake/wobble? Had to replace the tensioner pulley and belt bout 2wks back. I figure the tensioner pulley had just gone bad and taken the belt with it but after I installed it I noticed the crank. I'm assuming the shake/wobble of the crank was what took out the tensioner pulley.
Truck is a 99 nbs w/ 207+k miles. Its got the original pulley on there. Any help is appreciated.
Thanks,
Thanks,
it may be loose and about to fall off. if it has been like that long enough, it may have chewed up the inside of the pulley or the crank snout. if the inside of the pulley is damaged, and the crank is fine, than yes another pulley will do the trick
thanks for the reply.
yeah, i agree. just look at your crank and pulley and see if there is any visible damage. if not, you can put the stock pulley back on with a new crank bolt. as said above.
Thanks fellas appreciate the help.
