ORY or X pipe?
ORY or X pipe?
I am getting some LT headers on my 2005 HD and was wondering if I would be better off with the ORY or a X pipe I will be doing a custom exhaust so I can do either one with bullet mufflers. Thanks For any help
TOTM: January 2007
An x-pipe is used to balance out exhaust pulses. You need true duals to have an x-pipe that is functional. The best place for an x-pipe is close to where the 2 pipes meet. Usually on the passenger side underneath the cab.
Since you have a 2500HD with a 6.0, you probably dont have a y-pipe. You have 2 seperate pipes that run parallel down the length of the passasenger side of the truck and merge after the muffler.
A ORY pipe will probably give you more power than an x-pipe since cats are a restriction. The more power you make, the more power you will lose through your cats.
