outlaw cai
#22
So how do I tell which one I have? I think there is a serial number on the outlaw...the filter is a cone filter and red element with a black cap on the end of it...does that help?
#23
#24
I think my Outlaw is a POS.
Cons:
The box and tube run way too hot, the plastic is cheap, the Heimholz sits directly over the hottest hose in the bay and it whistles like a clogged vaccum cleaner under load.
Pros:
It picked up 5/5 on the dyno just by slapping it in and it's a great hiding spot for a dry kit.
Cons:
Pros:
#25
Cons:
Pros:
Cons:
Pros:
#29
Honestly, for a good, cheap dry filter closed element hollow out the bottom of your stock air box. Then you can either make or buy a short ram intake tube to replace that factory junk one. I actually think they sell a short ram intake tub on stylin concepts or you can build one from Lowes. You will save the expense of about $300 this way. I just fabbed up a 10 inch K&N air filter to fit on the end of a K&N short ram tube. I mean you can go buy an intake, but doing it this way you can save cash for more mods.
#30
Either that or surf ebay and you can buy 3' sections of polished aluminum tubing and polished 90* elbows...you could make your own for very little actually...especially the tubing.
