P0300 multiple cylinder misfire
We finished doing the cam today and since I didnt have my laptop we simply adjusted the idle screw on the TB to keep idle. After driving for a bit I got a few codes.
1. was the for the idle, which I expected
2. was the P0300 for multiple cylinder misfire. I tried to get some new plugs but the guy at service said that I needed to check my coilpacks since they used 2 different kinds. Im going to pick up new wires tomorrow and hope does it. What else could it be?
I havent done any tuning yet but it feels sluggish as well.
Originally Posted by dancar
It's the cam causing the code. I have the same thing if I let mine idle for very long. Brian from pcmforless is going to open the paramiters on mine to prevent.
Originally Posted by parish8
with tuners you should be able to just turn off that test.
when that code is set your converter wont lock up.
Performance Trucks Sponsor
I noticed that the converter wasnt locking. I read that I could reset the perameters, but I want to make sure that it isnt something serious. Is this a common thing with larger cams?? Its only a 212/218
If you want to get rid of it, simply put the value "32000" in all the cells that aren't above 32000 in the misfire tables.
You can slowly increase these values from the defaul setting until it quits setting the misfire code, but you'll probably end up around 22000 as the final value. This way if you have a serious mifire from a plug or wire, the pcm will eventually set a misfire code.
good luck,
allen
From: Somewhere between Auburn, AL and Columbus, GA
My friend put the 212/218 in his 5.3, got the same code and it was cleared up by tuning.
Thanks everyone. When I posted this the search function wasnt working. There is a ton of info about this in older threads, but I really appreciate everyones help. Im going to go ahead and replace the plug wires since they are due anyway. Guess I have to start tuning now.
Tydriver
45
10-23-2015 10:19 PM
