PAC 1518, TEA .660, or patriot extreme dual gold?
MASS seller approved
I got my spec cam info from pat g and he recommended the PAC 1518 or TEA.660 . What I was curious about is what other spring options are out there that compare to the two above. I know the Patriot extreme dual gold are liked by a lot of people I was curios if that compares to the other two. My specs are 218/222 .598”/.602” 114LSA +1 advance . I will be using Harland sharp 1.7 along with it. But what do u guys think as far as springs?
i have patriot dual gold extremes they can handel up to .660 and after 2k miles they seem to be working good
you will be happy with the pat g cam i had a 219 222 .607 .602 111+4 with bolt ons i got 365 /369 to the tires with a 4wd 5.3
have you consider the lunati dual springs there rated for .660 lift cams and there a tad cheaper ...
Gold Dual Valve Spring Kit For GM LS - Lunati Power
I was wondering if there is a quality difference between the PAC 1518 and the patriot dual extreme . I was thinking in the sense u get what u pay for and the PAC 1518 is 260 just springs and the patriots are 250 for spring locks and titanium retainers so I wasn't sure if the PAC 1518 are over priced compared to the patriots or are they far better quality. I would like to get the patriots because many members like them and have little complaints. But it really boils down to which is better quality?
