Pacesetter Header / Noise
Installed my Pacesetter about a month ago repaired broken bolts and running good. Except noisy. There is this fuzzy or leaky noise coming from the exhaust. Installed the pipe joints and sealed with band clamps. Is this a typical noise? Should I go ahead and weld up the y-pipe joints connecting the two sides and the piece after the y-joint to the muffler flange?
Sounds like junk driving along side a wall or low speed stuff where I can hear it.
P.S. this is running back to a large 22” magnaflow dumped before the axle.
Pacesetters have that "old school" header tic. Like you would expect when your listening to a build muscle car. But not a flutter. Band clamps are great and we all use them but they can leak. Just clean off the surface and seal both sides of the clamp with high temp RTV. That should solve your problem.
I woulden't worry about it dude. Mine does the same thing. At first it drove me crazy. I went over the damn thing with a stethascope and coulden't find anything. Like posted above, the will give you the "classic" valve tick sound. It comes with the territory. If you got it loud enough...you won't hear it...lol.
same thing with my pacesetters. i've never posted about it because i didn't know how to describe the sound. its like a disel truck sound. you hit it on the head that it sounds fuzzy.
anyway, is there no way of fixing this fellas? i would like to get rid of that sound for sure.
Originally Posted by 99Silver6.0
With my head stuck under the hood I cant heard mine make any noise. Quiet as stock.
Is this where people have installed bullet mufflers to help with?
Superman09
09-25-2015 05:55 AM
