pacesetter lt
Old 02-13-2007, 05:38 PM
slownlow4.8's Avatar
Default pacesetter lt
my headers came in to day."finally" just wanted to know what kind of gasket you all are using, OEM or something else
Old 02-13-2007, 05:41 PM
My pacesetters came with white gaskets and wiring to lenghthen your o2 wires.I think the stocker will work fine.
Old 02-13-2007, 05:47 PM
dirt track racer 81's Avatar
mine and dozerdans came with copper gaskets
Old 02-15-2007, 08:23 PM
are they supposed to come with necessary gaskets and fasteners
Old 02-15-2007, 09:14 PM
Guess it depends on who you bought them from, I think mine came from speed engineering. with gaskets, wiring, but no bolts.
Old 02-15-2007, 09:26 PM
i bought them from speed engineering so should i have gaskets, wiring too
Old 02-15-2007, 09:47 PM
KevinF56's Avatar
i had copper gaskets with mine which i used. but i didnt have an egr block off plate. go figure. guess it just depends on what you get with them. you can reuse your stock ones, but i'd suggest maybe going and buying stock ones. cant hurt to get some clean ones in there.
Old 02-15-2007, 10:01 PM
yeah i'll most likely buy new stock ones
Old 02-16-2007, 06:48 PM
xlcooplx's Avatar
im going to reuse the stock ones when i install mine as they will work perfectly fine. if you've already reused them once though, i would consider buying new ones.
Old 02-16-2007, 06:55 PM
blake2kz71's Avatar
i used oem on mine and no problems here. i also used dynatech 2 bolt stainless clamps instead of the ones that came with them.
Quick Reply: pacesetter lt
