Pacesetter LT install tips tricks
You guys have done the installs, I got a set with 4x4 y-pipe to install. Do i want the heads to be warm when I remove the manifold bolts? I have one broken off on the drivers rear (behind the steering shaft). Not sure why, the truck came that way when I bought it used. Probably was going to put headers on till that happened since it had duel exhaust already. Any idea how I can get that sucker of, not sure if its broke above or below the surface of the head.
The tranny crossmember has to come out, anything else I need to know?
Thanks
Thanks
tranny cross member has to come out? damn it ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
you're probobly taking the head off to get that bolt out dude. sorry I'd be suprised if an E-Z out could get it out, but id be really hard pressed to think you could get an E-Z out and a drill on it with it on the car.
Let it cool off though, then blow PB blaster all over the bolts.
I did a little write up when I put mine on. Open to any questions.
https://www.performancetrucks.net/fo....php?p=3444574#
Removing the tranny crossmember is not hard. Impact gun makes it easy.
Originally Posted by duwem
I have 103,000 Wisconsin(winters) miles, probably never taken off...should be interesting......
Originally Posted by treyZ28
Les, you honestly have some of the worst grammar I've ever seen in my life ![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
sorry i love periods and i cant spell leave me alone
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
PB blaster is a penetrating lube you can get at any auto store
