Pacesetter's with stock Y pipe possible at all?
Is it possible to fab up the stock Y pipe and retain the cats and use it with pacesetter LTs?
I need cats because I don't want any more resonance, and don't want the smell. I want to do a cam swap but most said it would be worthless without headers. Thanks.
You didnt say what your truck is, but I just put some pacesetters on my 2500hd 6.0 and kept my stock mid pipes and cats. I dont have a y like the 1500's but two mid pipes that go from the manifolds to the muffler. I just took it to my local muffler shop and they made a few cuts and welds and that was it. So yes it should be possible.
And on a side note my longtubes made my truck way quiter than it was with the manifolds. It was crazy, I had a magnaflow 22" muffler welded in before the header install and it sounded really good. But after the LT install the truck sounded stock again, i couldnt believe how much the lt's quited down the exhaust note. So I had the front 2 pup cats removed and left the rear's and all is well again. The 04 2500's came with 4 cats. 2 pre cats and 2 main cats further back before the muffler.
I still have my stock Y pipe and cats so it is possible they just have to to a lot of butchering to ur stock Y pipe it get it to work... but if I had it all over I would just have had the cats removed if you ask me after a cam swap mine stock cats didnt last long... IMO
