Pacesetters or these LT's for my LQ4?
Old 09-24-2011, 07:52 PM
Yukon04's Avatar
Wow 250 for long tubes good deal, I have a local ceramic coating shop here so whatever I purchase I can get them coated cheap.
Old 09-24-2011, 11:12 PM
2000chevysilverado's Avatar
the obx headers look nice but I didnt like them rubbed on fram and on cross member I priced a set of pacesetters on ebay for 262 for painted and a y pipe for 152 way better than obxs and may not match but your fitment a performance will be better grand total was 415 compared to 525 for obxs
Pacesetter Y-Pipe 00-06 Chevy/GMC Pickup 4.8L/5.3L V8 | eBay
PaceSetter QuickTrip Long Tube Headers 70-2265 | eBay
Old 09-25-2011, 06:01 PM
static06's Avatar
hows the fitment on the pacesetters? do they hang down real low? reason i ask cause ill be ordering a set with y-pipe and im worried about the clearance ill have since im 5/8 and have about 3 1/2" of frame clearance. idk if it'll be good or no
Old 09-25-2011, 07:14 PM
you should be fine the will fit in with inline of the fram just like any other headers should they shouldnt hang any lower
Old 10-09-2011, 07:51 PM
Doc_speeder's Avatar
Time for an update. I installed these today. Took about 4 hours with a lunch break and a beer break. Will be taking the truck in later this week for the rest of the exhaust fab/install.
I ordered these ones:
Fit was great. There was a little protrusion on the bellhousing of my 80E that needed to be ground down a bit. Lots of clearance for the O2 sensors and good space from the front driveshaft.
Primaries are 1 5/8" i.d., collectors are 3". Very nice headers. Sounds pretty mean dumped right out the collectors for now...
Here's the old pass side manifold. Think this could be the cause of my exhaust leak??? It's broken clean all around. Just the flange holding it together!
Old 10-09-2011, 08:14 PM
bai78's Avatar
Looks good....Are you planning on some sort of slip fit to the cats, flanges, or just a straight weld?
What are your plans for muffler, tips, & exit?
Old 10-09-2011, 08:38 PM
No cats. 2.5" pipe with a resonator in each to a DI/SO 22" Magnaflow exiting in the stock tailpipe location.
Slip fit on the collectors with band clamps.
Old 10-09-2011, 09:14 PM
Nuclear Endless's Avatar
Which did you order? The original link you posted?
Old 10-09-2011, 10:15 PM
Yep, the ones I posted the link for.
Old 10-12-2011, 01:05 AM
PT's Slowest Truck
budhayes3's Avatar
Dan (DV2000NJ) has those same headers...they're basically the truck OBX's without the silly hump
Quick Reply: Pacesetters or these LT's for my LQ4?
