Paging Parish8
Paging Parish8
Hey Parish...you still have that knocking noise in you 6.0 when cold at 1/2 throttle?? I dug up your old post about it. Since mine seems to be doing the same thing I thought I would see if yours has gotten any worse or not.
Randy
Randy
yep still got it, it is way worse when the truck is really cold, like siting outside and 15deg out. over all i would say it is no worse than when i first fired the motor and i have ran at least 50lb's worth of nitrous thru it.
when i was talking to seth at cmotorsports about the turbo set up i told him i didn't know how long my motor would last once i start pushing it with tht rod knock and he told me his truck only has 50k on it and it has a rod knock also, he is very confident it is a rod knock too.
he also said the turbo shouldn't put any extra stress on the rods and wont likely speed it's death. he didn't seem worried and plans on pushing his stock motor hard.
I'd feel much better about it if I knew what it was. It sounds like ragged **** when it's cold. I'm probably going to drop my oil pan again this weekend and take a look up in the cylinders from below and check the rod bearings.
Originally Posted by Flyer
Have you thought about pulling the heads?
Originally Posted by gonzo 6.0
I will say it's more likely piston knock/slap when cold.A rod would make more noise when hot and the oil is thin.
Preshr
03-22-2016 02:22 PM
Stainless Works
10-08-2015 12:01 PM
carid
09-10-2015 09:07 AM
