Painting headers worth it?
Just got a set of pacesetter lt's the cheapest ones
New , should I sand n paint w quality stuff ?
Can I sand em or use paint remover and just leave em be w no paint up.
Anyone done this.
Thx for the help
Anyone done this.
Thx for the help
It mainly depends on the surface prep. It won't last forever, but you can make it last longer.
If you sandblast the headers and then wipe them down with a solvent it would be ideal. Do not touch them with bare hands. Sandpaper wont cut it either.
Thx coban. To bad I don't have access to a sandblaster. Just finished sanding em w paper n dremel. Could be worse I guess Then rustOleum. High heat.
I have the same LT's bro and i sanded them down completely and primered them and used some high temp paint, after a few cycles the truck started smoking up but after they get that "greyish" color to them. There holding up on me for now. good.luck bro
I would wet sand them, wipe them down with mineral spirits or some thinner, 2 light coats of primer and a black paint. Corrosion loves sanded metal unprotected. Humid at CC Tx. is no joke too!
sauldgold
07-23-2015 02:15 PM
