Are Patriot Gold Duals Too Much???
I am planning on running an aftermarket cam on my 5.3L by comp or lunati. The comp cam lift is like .529 and the lunati is like .535. I don't know which one I am going with yet, but I was wondering if it was possible to over-spring a cam? Would the patriot duals be too much spring for a cam around the lift listed above? Would it hurt anything too go with springs that stiff on a somewhat smaller cam?
Well for starters the duals come with titanium retainers, locks, and all new seals. Plus I figured it would be safer to run the duals? I figured the duals would last longer than beehive springs as well? These are all assumptions of course. If their are any other thoughts feel free to chime in.
While yes of course they are more than you need, but if you believe for what ever reason that you may catch the mod bug like alot of us and will end up changing the cam again in the future, at least you will have the spring swap out of the way. The springs, next to the crank bolt is the biggest pain anyway. Now if this was an old school flat tappet motor, then no - never over spring, as you would have a good chance of flattening a lobe early,
well its in my girlfriends bedroom right now cuz i got a lot of parts but still need a couple to do the swap (replacin heads and lifters ) but i did a lot of reaserch and it seems like im gonna enjoy it alot!
