Patriot Heads & Cam
Patriot Heads & Cam
I'm thinking of using Patriots head & cam package on a 5.3, Stage 2 or 3 heads with 2.05/1.60 valves. The cam is 226/226 duration .585/.585 lift 112* lsa. The rocker assembly is 1.7:1.Thinking also of about spraying a 100 shot.
Anybody have an opinion, can I do better with another manufacturer's equipment. It will see some track time.It will be on the truck in the sig. Brian
Originally Posted by ByuTrukFreak
I'v got HPTuner and I was thinking of the Vigilante converter with at least 3000 stall, will the stock trans last very long with this setup?
