Pcm controlled fans
Old 07-29-2004 | 10:50 AM
2003blue5.7's Avatar
Default Pcm controlled fans
What do I need to painless controller to having the pcm operate them? I know it's pin #42 in the pcm and it needs to be turned on by ls1 edit but do I need a special connector? Just one wire goes to the computer?
Old 07-29-2004 | 12:33 PM
The_Mexican's Avatar
Check http://www.nelsonperformance.com/gmparts.htm
"Our fan harness is direct replacement for the Flex-a-Lite VSC. It's also available for truck owners who use the LS1/LT1 style Camaro fans. The fans are controlled by a set of relays that are triggered by the PCM and a/c signal. The harnesses are made from high- quality TXL rated wire. Every terminal is crimped and soldered to avoid corrosion and contact problems. Each one is covered in wire loom and comes with all parts/connectors. No need to run to the auto store for a part.
For the Flex-a-lite owners, the power wires come with a heat-shrink terminal so you will be able to attach to your existing fan wires.
For LS1 sytle fans, OEM weather-pack terminals are included. This makes it an easy plug-n-play design. A manual switch and LED's are available as options. "
Old 08-04-2004 | 01:28 PM
bodyguard6799's Avatar
Default No LS1-EDIT??
So by using this fan harness you dont need the LS1-edit???
Old 08-04-2004 | 01:53 PM
one03sierra's Avatar
Formerly one92rs
Talking
no you will have to turn it on in the pcm with edit.
Old 08-04-2004 | 01:58 PM
SSMinneapolis's Avatar
edit, hptuners...whatever works..
but the wiring harness is pretty slick...
SS94S10
01-03-2019 01:57 PM
Porscharu914
14
01-20-2016 10:45 AM
97gmc
22
09-08-2015 10:56 PM
muncie21
09-07-2015 09:55 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: Pcm controlled fans
