PCV question
I pulled the PCV off the manifold and off the throttle body and let the truck idle for awhile. Still burning oil. Ran it up a little bit, oil cleared, brought it back to idle, after a minute or two it started smoking again. Looks like it's something else.
When you pulled off the PVC hose, was it "steaming"? Was it pretty obvious that it was was a burnt oil smoke/steam coming out?
My brother had a 87 YJ, Jeep, and the carb was always clogging up, and there was so much blow by coming out of the PVC that we just ran an open hose to the ground and left it that way when it was sold. At 2,500-3,000 on the freeway, it was as if he was spraying for buggs out of that one pipe that was dumped. His was from either a cracked piston, or busted rings.
PT's Slowest Truck
I'm going to assume that the heads have been ported, and throw an idea out there. If the rings and valve seals are OK, is it possible that oil is leaking past the threads for the rocker arm bolts? I know that when I got my 317's back from WCCH, I could see straight through the bolt holes to the ports (can't remember if it was intake or exhaust ports...I think it was intake, and I don't have the heads with me). After some research and talking to Richard at WCCH, I found that this is common with certain GENIII heads, and that some form of sealer should be used on the rocker bolts (teflon, etc.).
*edit* I just talked to TSP and they said the bolt holes do go all the way through.
