PCV question
#22
Originally Posted by thunder550
I had Jon at TSP check with his techs, and they told me to make sure to seal up the intake rocker bolts with black silicone, which I didn't do. I'll try that next and see what happens.
#23
ok found what I was looking for, but doesn't sound like anything similar to what you're dealing with
https://www.performancetrucks.net/fo...d.php?t=379485
#24
High on diesel fumes
It would be cool if that's the problem!
Tootall - thanks for checking that out. Definitely not anything that I'm dealing with, but it's good to know anyway.
#25
Post #7
https://ls1tech.com/forums/showthrea...cker+bolt+seal
Looks like it might be a common problem.
#27
Well ****. that didn't fix it. I need to get off my *** and do a compression test. I used Permatex high temp sealant on all the rocker bolts and let them cure overnight before driving. Still smokes this morning.
#29
I drove it around this morning and let it get up to temp. Went home and parked int he driveway and left it idling. After about a minute it started smoking again. I'll drive it around some more and run it up and down a few times, but I don't think that's going to fix it.
