People running 11.5+CR how are you liking it?
#27
I have a gauge for that
Its dynamic compression ratio. Basically because of the speed of everything going on in the engine, the cylinder isnt completely filled like it would be in static conditions where static compression ratio is calculated. SCR is usually the compression ratio thrown around because it depends only on the piston specs, and cylinder head specs. To calculate dynamic CR you need to know the cam specs in addition to the things needed to find SCR. To find DCR you need to know when the intake valve closes after bottom dead center (ABDC), which depends on the cam being used.
#29
from this website: http://www.empirenet.com/pkelley2/DynamicCR.html
I like this calculator http://www.kb-silvolite.com/calc.php?action=comp
Calculating DCR: Calculating the DCR requires some basic information and several calculations. First off, the remaining stroke after the intake closes must be determined. This takes three inputs: intake valve closing point, rod length, and the actual crank stroke, plus a little trig. Here are the formulas: (See the bottom of the page for a way around doing all this math.)
Variables used:
RD = Rod horizontal Displacement in inches
ICA = advertised Intake Closing timing (Angle) in degrees ABDC
RR = Rod Distance in inches below crank CL
RL = Rod Length
PR1 = Piston Rise from RR in inches on crank CL.
PR2 = Piston Rise from crank CL
ST = STroke
1/2ST = one half the STroke
DST = Dynamic STroke length to use for DCR calcs
What's going on: First we need to find some of the above variables. We need to calculate RD and RR. Then, using these number, we find PR1 and PR2. Finally, we plug these number into a formula to find the Dynamic Stroke (DST).
Calcs:
RD = 1/2ST * (sine ICA)
RR = 1/2ST * (cosine ICA)
PR1 = sq root of ((RL*RL) - (RD*RD))
PR2 = PR1 - RR
DST = ST - ((PR2 + 1/2ST) - RL)
This result is what I call the Dynamic Stroke (DST), the distance remaining to TDC after the intake valve closes. This is the critical dimension needed to determine the Dynamic Compression Ratio. After calculating the DST, this dimension is used in place of the crankshaft stroke length for calculating the DCR. Most any CR calculator will work. Just enter the DST as the stroke and the result is the Dynamic CR. Of course, the more accurate the entries are the more accurate the results will be.
Variables used:
RL = Rod Length
ST = STroke
Calcs:
PR2 = PR1 - RR
