Performance Parts questions * NEED HELP *
I have a 2011 Silverado 2500HD and i was wondering if I could use performance parts from a 1500 6.0 for my 2500HD 6.0? I'm working on making my truck a sleeper and I can't for the life of me find a Supercharger kit for my 2500HD, I can only find superchargers for the 1500s and 2500 HDs outside of my model.
It depends on the year of 1500, and/or look at the applicable engine codes, if the manufacturer lists that info
I suspect the problem you are encountering is that you have square port heads with truck FEAD spacing
You can also look at 5th Gen Camaro kits, as they will fit square heads and have *almost* the right spacing. There is about a .05" difference, but its not enough to matter based on the thousands of LSA swapped trucks out there
02gmcbandit
02-04-2013 08:57 AM
ndependent
09-19-2009 01:54 PM
