Perma-Cool or Flex-A-Lite
I Love My Fal's. Bought them on ebay, used. The only problem I had was Pulling my boat in the hottest part of summer, I didn't have any 10 Gauge wire when I installed the fans so I used 12, well it drew enough to blow the 30 amp fuse (was supposed to be 35+) Got to the boat ramp and wasn't going to let the truck sit there at 250*+ so I jumped the fuse with some old christmas light wire I found, Thats the **** that catches on fire, I was letting the fans run while I was preparing the boat. came around the front of the truck and that friggin wire was on fire. didn't have no gloves, Nothin, had to use a friggin lighter to jerk the wires out " Brilliant" It didn't blow
So when I got home I changed all the wiring to #8 and have never had another problem. My VSC is fine, just use the size wire they tell you, or bigger. and there won't be enough draw to heat the vsc......
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
![Hail](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_hail.gif)
I've got the FAL's and had to replace one of the motors. I understand they had a bad batch of motors with failing bearings. Other than that, there have been no issues. They definitely free up some power and give you a lot more room under the hood.
Hemi Killer
09-07-2004 07:57 AM
1BADHD
09-04-2003 06:46 PM
