Picked up a 99 Tahoe...
Old 03-14-2002 | 04:43 PM
  #21
Pro Stock John's Avatar
Registered User
Default Re: Picked up a 99 Tahoe...
2000 Silverado LM7/5.3 liter:
5.3L V8 (LM7/L59)
Displacement: 5328cc
Compression Ratio: 9.5:1
Valve Configuration: Overhead Valves(2 valves per cylinder)
Assembly Site:
Romulus, MI
St. Catharines, ON
Silao, Mexico
Valve Lifters: Hydraulic Roller
Firing Order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x Stroke: 96.01 x 92.00mm
Fuel System: Sequential Fuel Injection
Horsepower: 285 @ 5200 rpm
Torque (lb-ft): 325 @ 4000 rpm
Fuel Shut Off:
5600 rpm with Manual Transmission
5900 rpm with Automatic Transmission and Electronic Throttle Control (ETC)
6000 rpm with Automatic Transmission without ETC
Emissions Controls:
Evaporative System
Catalytic Converter
Exhaust Gas Recirculation
Positive Crankcase Ventilation
APPLICATIONS
GMC and Chevrolet 1500 and 2500 Sierra and Silverado and Chassis Cab (LM7)
Yukon and Tahoe (L59/LM7)
Yukon XL and Suburban (L59/LM7)
Cadillac Escalade (LM7)
Chevrolet Avalanche (LM7)
MATERIALS
Block: Cast Iron
Cylinder Head: Cast Aluminum
Intake Manifold: Composite
Old 03-14-2002 | 04:47 PM
  #22
Registered User
2002 Product Specifications
8.1L V8 (L18)
Displacement: 8128cc
Compression Ratio: 9.1:1
Valve Configuration: Overhead Valves (2 valves per cylinder)
Assembly Site: Tonawanda
Firing Order:1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x Stroke: 107.95 x 111.00mm
Horsepower:
340 @ 4200 rpm (L18)
270 @ 3600 rpm (MD L18 w/LQY power option)
210 @ 3600 rpm (MD L18 w/LQQ power option)
Torque (lb-ft):
455 @ 3200 rpm (L18)
400 @ 1600 rpm (MD L18 w/LQY power option)
325 @ 1200 rpm (MD L18 w/LQQ power option)
RPM Limiting:
5000 rpm (C/K, G)
4000 rpm (MD with hydraulic brakes)
3800 rpm (MD with air brakes)
Emissions Controls: Exhaust Gas Recirculation
APPLICATIONS
Chevrolet Avalanche
2500HD and 3500 Sierra and Silverado pickup and crew cab (option)
3500 Silverado and Sierra chassis cab (option)
Classic Sierra 3500HD chassis cab (base)
Suburban and Yukon XL (option)
Express and Savana (option)
MD Series B-7 bus chassis (option)
MD C-Series 55/65/75 (base)
MATERIALS
Block: Cast Iron
Cylinder Head: Cast Iron
Intake Manifold: Cast Aluminum
Exhaust Manifold: Cast Stainless Steel
Main Bearing Caps: Cast Nodular Iron
Crankshaft: Cast Nodular Iron
Camshaft: Steel
Connecting Rods: Forged Steel
Additional Features:
Coil-near-plug ignition
Electronic throttle control (non-OEM only)
Oil life monitor (New pickup and MD)
Oil level sensor (New pickup)
Extended life coolant
Platinum Tip Spark Plugs
dsbodley
11-14-2015 10:46 PM
cheyenne383
11-13-2015 10:24 AM
Gadgetized
10-22-2015 10:06 AM
gmcyukon
10-05-2015 07:20 AM
Mark_k
10-02-2015 12:17 AM
