Pickin up a 4.8 truck. Parts for best MPG?
#31
are you guys all 2wd? my 5.3 4wd (in 2wd mode) wont get better then 15-15.5mpg, alot of highway driving but some city.
has a bed cover, but maybe 200-250lb's worth of tools and such.and ive started to tune it some for 89 octane. could possibly use a little more timing on the highway, but mileage sucks so far.
it is cold up here though, we usually loose 2mpg in the winter. e fans to come soon hopefully.
#33
Bottom line, if money IS an object, a good tune will be your best investment because it can improve your performance and your MPG over stock and, if you get a tune that includes updates, you can have it adjusted as you begin with your mods. Unless you can do (and undo) the work yourself, I'd hold off on the TC; from what you say about your plans and all, I don't think you'd like a high-stall converter. That's just my opinion based on what you've said here. Hope this helps!
From what you've said, I'd think that a cam like mine (in sig) would work well for your needs. You'll notice a power increase throughout the rpm band and fuel economy shouldn't suffer, it may actually increase.
You should get better mileage in the cold.
#34
sorry been gone a little while, had a wedding to attend last night and im still feeling the effects of the afterparty today.
budhayes3, with my month payments lowered than i thought theyd be at the first of this thread, ive got a little spendin money extra so i want to do a cam swap and tune right off the bat. you said a cam like in your truck would work well..; you mean that "206/212 .515/.520 114" ya got in your quote at the bottom? thats the best bit of info ive heard all day from this forum specialy since its a close cam to what Jake recomended for me.
are we not allowd to talk about custom grinds on this site? ive asked a couple times now what yall think about that custom cam grind an mums the word lately. if we cant talk bout them im sorry, i didnt know.
#35
Yessir, I was referring to 206/212 .515/.520 114, which actually is a custom grind since the off the shelf cam came on a 112 at the time. You can talk about custom grinds all you want, I guess that nobody has any input about that though.
At the time, Comp recommended that I get the cam ground on a 114 to reduce the possibility of the PCM picking up false misfires, but tuning has come a long way since I bought my cam. Comp has 2 versions that are similar to my cam, one on a 112, and one on a 115. The 112 will produce torque sooner and be more peaky, as well as idle a little choppier, while a 114 or 115 will idle smoother and have a broader torque curve.
#36
oh yes. Living in MN all gas stations here are oxygenated and they have been for years. i forget that not all gas stations are 10% ethenol like they are here. non oxy stations are few and far between here.
i suppose on non oxy i would be seeing 17 or so. even though we use oxygenated gas all year, the gas is even worse in the winter and we drop 2 or so when it gets cold.
thanks for the welcome~ ive been lurking for a little while
#37
My Tahoe with 33" mud tires does better than that. Yes it has more displacement, but weighs 1000 lbs more.
5.3Caprice
11-07-2015 09:56 PM
