Pics/Instructions on 99 water pump replacement
Old 12-16-2008, 08:34 PM
  #21
eallanboggs's Avatar
I've been using a chain wrench for years(sold in plumbing supply stores or Sears) to hold the pulley fast while I remove the bolt.
Old 12-16-2008, 09:04 PM
  #22
TG02Z71's Avatar
Mine did the same thing, easy to change out, i did this in the parking lot at work in 25 minutes. I posted pics a longggg time ago, may still be up.
Old 12-16-2008, 09:25 PM
  #23
SPAM HUNTER
2005 Silverado's Avatar
Just some info,(everyone most likely will already know this but) waterpump gaskets aren't the only thing that can leak on a waterpump, there is a seep hole that will start to leak when the waterpump is well...DONE. It can also leak out the from seal, check for play and noise.
Dustin
Old 01-08-2009, 03:25 PM
  #24
Air Hammer with a flat blade in it also works good for breaking the nut loose. Just leave the belt on to hold the pulley while you hit the nut with an air hammer a couple times. Put it back on the same way.
Old 01-08-2009, 04:58 PM
  #25
negativeswitches's Avatar
should be advised if you take it off with that method that you may not be able to use a wrench on it later if you had too
ullose272
08-05-2016 02:05 PM
thunder550
10-08-2015 04:53 PM
05GMC4.8
08-07-2015 09:55 PM
InsaneDomestics
07-27-2015 02:42 PM
Quick Reply: Pics/Instructions on 99 water pump replacement
