Pics/Instructions on 99 water pump replacement
#23
SPAM HUNTER
Just some info,(everyone most likely will already know this but) waterpump gaskets aren't the only thing that can leak on a waterpump, there is a seep hole that will start to leak when the waterpump is well...DONE. It can also leak out the from seal, check for play and noise.
Dustin
Dustin
#24
Air Hammer with a flat blade in it also works good for breaking the nut loose. Just leave the belt on to hold the pulley while you hit the nut with an air hammer a couple times. Put it back on the same way.
05GMC4.8
08-07-2015 09:55 PM
InsaneDomestics
07-27-2015 02:42 PM
