Pics of some bad brakes
Old 02-23-2004 | 12:11 PM
  #21
yes dealer only they cost around 75.00-100.00
Old 02-24-2004 | 04:16 PM
  #22
Originally Posted by KeukaZ71
what do you think i should do? should i replace with a better caliper? i hate to see me mess up the new pads and rotors
The advise above is correct
The pad wear is from a sticking caliper or slides
I would remove the caliper
take the slides apart - clean them real well and lube
and bleed that caliper
See if that makes a difference - if no - then it will need a caliper
Old 02-24-2004 | 05:26 PM
  #23
KeukaZ71's Avatar
what lube would i use?
Old 02-24-2004 | 06:00 PM
  #24
jlwz71's Avatar
Right Rear Inner Brake Pad Wear (Install Rear Wheel Mud Flaps) #00-05-23-005B - (05/27/2003)
1999-2004 Chevrolet Silverado 1500 Series Pickup Models
1999-2004 GMC Sierra 1500 Series Pickup Models
This bulletin is being revised to change the content from Informational to Technical. Please discard Corporate Bulletin Number 00-05-23-005A (Section 05 - Brakes).
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1336875&evc=numSrch#ss1-1336875">Condition
Some customers and dealers may comment on accelerated rear brake wear on some of the above listed vehicles. This condition occurs mainly on the right rear inboard brake pads and on vehicles that are exposed to extensive off-paved roads.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1336875&evc=numSrch#ss2-1336875">Correction
Install a mud flap forward of each rear wheel using the following procedure. Installation of these mud flaps and following the recommended off-road driving information provided in the vehicle's Owner's Manual should greatly reduce the possibility of accelerated rear brake component wear.
Important
Always work from outboard to inboard, drilling one hole at a time and securing with a fastener. Follow the sequence of the procedure. This will prevent distortion of the mud flap.
  1. [*]
  2. [*]
  3. [*]
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1336875&evc=numSrch#ss3-1336875">Parts Information
Part Number
Description
Qty
15765007
Flap Package - Rear Mud
Parts are currently available from GMSPO.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1336875&evc=numSrch#ss4-1336875">Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B7787*
Flap Package, Rear Mud -- Install (Both)
0.6 hr
*This is a unique labor operation number for use only with this bulletin. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Document ID# 1336875
Oobray
06-13-2022 03:38 AM
SLOPONY
20
10-18-2016 06:05 AM
YenkoST
12-02-2015 11:36 AM
chacho44
08-17-2015 03:36 AM
Slammed96
07-27-2015 07:22 AM
Quick Reply: Pics of some bad brakes
