pinging?
sounds to me ur going to have to get 24lb injectors to match your tune, might not be cheap, but it will save later with the way you are having to mix gasoline!! maybe u can find a member who swapped their injectors, and buy them for cheap! hope u work it out man!
jared
jared
5 year bitches!
Originally Posted by tb8100
run 90 and use a bunch of octane boost!
Did you buy the PCM from Nelson, or second hand? You should call Allen and talk to him about the tune. Most likely, like others have said a 99 will have 19lbs/hr injectors and the 02 pcm will be setup for 24lbs/hr. You can usually find used 24lbs/hr for about $75-100, which would be a good upgrade for ya anyway. Or, Allen might be able to do some think about sending you another PCM with the tune setup for the smaller injectors. Either way, be VERY careful running your truck the way it is, denotation like what your talking about with break ringlands off your piston in a hurry.
Cuz I AM a BADMOFO
I sold a set of injectors on here about a month ago for $15! I'm sure the market is more than flooded with stock injectors with all of the guys going with the Radix....which comes with its own injectors. I sold an intake, injectors, and everything for $75. Look around, and ask in the classified section.
lucas287
31
01-12-2021 06:18 AM
Tydriver
45
10-23-2015 09:19 PM
Fast86z
08-23-2015 12:35 AM
