pinging while towing
Last night while towing a 20ft enclosed trailer with my truck i heard it starting to ping when i got to the 2,800-3,000rpm range when i back off a little i didn't hear anything it was just around that RPM range. i also towed in the tow mode in 3rd gear. My truck is a 4.8L 2001 GMC, i've up graded to AEM air intake, JBA headers, 3in flomaster exhust,from the cats back on back, 4.56 gears on 35's . no check engine light came on or anything. any thought's or suggetions to what would cause this ? the truck does have a 130,000 miles on it, mostly freeway.
thanks,
thanks,
PT's Slowest Truck
If this service doesn't help, you may have to look for a lean condition, EGR issue, vacuum leak etc. Might be worth it to use premium gas while your'e towing if necessary.
i did forget to mention i have a hyperhand held tune in if for the 87 octane, but i run 91 from different chevron's and 76 station out her in california, i was thinking of maybe changeing out the fuel filter thinking its' partial clogged and the motor isn't getting all the fuel it's suppose to, i just changed my fuel pump last month so i know it's not that.
thanks again
thanks again
Ever replaced your knock sensors? The back sensor is prone to rust/corrosion due to a chitty design where the hole it sits in is like a big funnel for water. When it happens the knock sensor doesn't make a connection and if it starts knocking it doesn't send the signal to retard the timing as needed. IIRC it turns on a check engine light but with that hyperpoo on there its hard to say.
