Piston Slap...WTF
Old 12-26-2004, 08:40 PM
  #21
since alot of guys that know of the slap issue are reading this thread lemme ask does this tend to effect the 5.3's more so? or any particular motor?
Old 12-26-2004, 09:40 PM
  #22
FILE's Avatar
I think it affec the 6.0 more.
Old 12-27-2004, 05:28 AM
  #23
therock's Avatar
Default 05 L33 5.3 W/3k miles and No Slap.
No slap yet. I changed to Mobil1 @ 500 miles.
I have had an 02 and a 03 with 5.3's and they both started slapping \ ticking at the first oil change.
Old 12-27-2004, 12:30 PM
  #24
I found a way to get rid(hide) that nasty slap noise. All you need is a p1sc. You cant hear anything over that bitch.
Old 12-27-2004, 12:45 PM
  #25
unklej's Avatar
You buy it for me and I will do it...HAHAHAHa
  #26
TG02Z71's Avatar
I beleive the piston slap issue can be traced to the tolerances (both dimensionaly and circularity) used to manufacture the pistons, and the fact that pistons are not round when cold. The engine warms up and the pistons "grow" into a more circular shape relative to what the GM engineers deem to be optimal. This is for sealing, reduced friction and compression. Some motors will knock more than others because some pistons will be higher or lower in the manufactures tolerance band. I have visited the company that makes pistons for the truck motors as well as other makes pistons and saw the process first hand and also disscussed the piston slap issue with their enginners. They were aware of the issues and said GM is changing things to account for this but did not say how. YES I TOO HAVE SOME PISTON SLAP........
Old 12-27-2004, 01:12 PM
  #27
You buy me a d1sc and I'll gladly give you my p1sc....hahahaha It would probably be cheaper to just turn up your radio though!
Old 12-27-2004, 08:51 PM
  #28
I have made piston slap on my 8.1, enough to where when i start it ive been asked by multiple people if i had the desiel, sounds just the older deisels when i start it up. think theres anything that can be done the dealer will fix?
Old 12-27-2004, 09:07 PM
  #29
I had piston slap at 10000 miles. 5 30 mobil one syn took it away. I currently have 91000 miles running strong and its a 99 5.3
Old 12-27-2004, 09:30 PM
  #30
unklej's Avatar
sounds good, I might have to try Mobil one at my next oil change.
Jeff
Quick Reply: Piston Slap...WTF
