piston swap
Old 09-20-2004 | 01:20 PM
Sport Side's Avatar
The 5.3 piston dish volume is 8.14 cc. By using a 4.8 flat top piston, you will effectively reduce your trapped volume by that amount.combustion chamber volume of 61.15 cc. Rough calc says over 11:1.
Ok, using your info, and the information provided on this thread static compression I come up with around 11.1 or just a penny or 2 higher.
btw, because im lazy and dont feel like searching. what is the relation between CR and milling? Say .040 milled off the deck of the cylinder heads. What sorta bump in compression would that lead to?
Bluecollar Hotrods
06-11-2024 11:37 PM
superchomper2003
08-26-2015 09:39 AM
lycominghunter
08-15-2015 12:26 PM
4B11T
07-13-2015 03:48 PM
NuckenFuts
07-09-2015 08:45 AM
Quick Reply: piston swap
