Plastigage results
Plastigage results
Ok, finally got a chance to plastigage the rod bearings. Everything checks fine so i'm sure it's not a rod knock and there is no slack in the wrist pins. Next on the list is to go ahead and replace the rod bearings while it's down and install arp rod bolts. After that i'm going to borrow a bore scope and check out the tops of the pistons.
Does anyone know where I can order a set of ARP rod bolts and a set of OE rod bearings today???
I need to get them by Tuesday if at all possible, cause if the pistons look good in the bore scope I still want to make my tuning appointment on this coming Friday.
Originally Posted by ranwalk
Just going back with standard size.Ordered them from Thunder Racing today.
Banned
i was gonna say thunder or speedtek....i just got a set of Clevitte(sp)rod and main bearings in for my motor today. both of the afore mentioned places will have the ARP bolts also. i think i paid 65 for mine from Speedtek. Ran, what is this plastigage?
Adkoonerstrator
Example.
You put one of the strips on a crankshaft main and bolt down the cap with bearing installed. Torque it to spec and then take it back off. The little plastic strip gets squished and then you use a little chart included with the plastigage to measure the clearances. The little strips get wider when squished and the little chart shows the clearance for how wide the strip is.
Really simple stuff that works good enough.
Cha_Feel_
09-23-2015 09:06 PM
FormulaZR
09-14-2015 05:23 PM
