please help, may have ruined heads
I had 3 header bolts that broke off in the head. I tried welding nuts and bolts to them, didnt work. I tried drilling and using an extractor, didnt work. So I went and got a 3/8 in tap and and drill and drilled them out. I started on the passenger side rear bolt and when I was just about done. I broke through something in the upper rear corner it feels like. What did I hit? Are my heads shot?? Please help!!
I took the intake manifold off and it didnt "go into the head" It didnt go in the exhaust or intake areas. It looks like maybe it went into the small area where the valve travels through the head. To be more specific it may have just gotten into the area where the last valve on the passenger side goes through the block. Is this going to cause problems? I cant believe how close that valve travels to the area where the last header bolt goes. Does someone know how serious this is?
looks like I didnt ruin them. Im just going to need to use some sealant when I get the bolt in there. So I start to tap the hole and the tap breaks off inside . Im going to take the heads off tommorrow and take them to a machine shop to have them remove the bolts on the driver side head and the tap on the passenger side. Im going to have them tap the passenge hole to 3/8 for the bolt. The rest of the header bolts will be the Stage 8 locking fasteners.
Originally Posted by moregrip
Just Heli-Coil it, no need to go 3/8"
Take the head to any machine shop,they can install a helicoil to fix the damaged threads.Installing a helicoil is easy,but at the rate you're going I'd use a machine shop.The helicoil thread will be as strong as the original,I've used them on stripped spark plug threads with great success.
I agree the machine shop should be able to fix it. If nothing else, the holes can be welded up and re-drilled and tapped with precision on a mill. That is the beauty of aluminum.
03regcab sierra
09-09-2015 02:02 PM
sauldgold
07-23-2015 02:15 PM
