Which plug for Radix?
#34
Originally Posted by moregrip
damn! the kids will play......
I look at it this way, if you got the tools, use'em
update: the heads are off, just cleaning up the piston tops, should be done tomorrow
My old man always told me Work Smarter, not harder.
#35
EDIT: BADMOFO, this is a copy and paste job, not an original composition
Indexing refers to an old racer's trick whereby the spark plugs are installed so that the ground electrode is oriented to face the intake valve (usually) in an effort to "open up" the spark to the incoming air/fuel charge. This is accomplished by placing a washer underneath the spark plug's shoulder area (of a specified thickness) so that after properly torqueing the spark plug, the electrode would be pointed in the desired direction, usually towards the incoming air/fuel charge from the intake valve.
Some racers have discovered that certain engine configurations made more power with the spark plug pointed away from the air fuel mixture.
It is important to note that any power increase will be small, typically 1-2% of total engine output, and the proper indexing orientation can only be discovered after extensive engine dyno testing.
Originally Posted by whitt1
Does anyone index their plugs?It's a pain in the you know what,but it's good for a few horsepower.
#40
why???
Do you have head studs or aftermarket bolts? Or are you removing and replacing the stock torque to yield bolts every time you take the heads off?
