Which plug for Radix?
Old 02-26-2005, 10:25 PM
  #31
what a rush!
moregrip's Avatar
damn! the kids will play......
I look at it this way, if you got the tools, use'em
update: the heads are off, just cleaning up the piston tops, should be done tomorrow
  #32
blownerator
BlownChevy's Avatar
update: heads are off, just cleaning up the piston tops, should be done tomorrow
That is what we figured.
Old 02-26-2005, 10:26 PM
  #33
Does anyone index their plugs?It's a pain in the you know what,but it's good for a few horsepower.
  #34
Flyer's Avatar
LOL ... Sea Foam would have done the same thing.
My old man always told me Work Smarter, not harder.
Old 02-26-2005, 10:28 PM
  #35
what a rush!
moregrip's Avatar
EDIT: BADMOFO, this is a copy and paste job, not an original composition
Indexing refers to an old racer's trick whereby the spark plugs are installed so that the ground electrode is oriented to face the intake valve (usually) in an effort to "open up" the spark to the incoming air/fuel charge. This is accomplished by placing a washer underneath the spark plug's shoulder area (of a specified thickness) so that after properly torqueing the spark plug, the electrode would be pointed in the desired direction, usually towards the incoming air/fuel charge from the intake valve.
Some racers have discovered that certain engine configurations made more power with the spark plug pointed away from the air fuel mixture.
It is important to note that any power increase will be small, typically 1-2% of total engine output, and the proper indexing orientation can only be discovered after extensive engine dyno testing.
Old 02-26-2005, 10:29 PM
  #36
what a rush!
moregrip's Avatar
you Texas boys are a funny lot
Old 02-26-2005, 10:32 PM
  #37
what a rush!
moregrip's Avatar
Originally Posted by BlownChevy
Make sure you use some anti-seize.
why???
Old 02-26-2005, 10:35 PM
  #38
Yeah,I guess I'm a old racer,but indexing the plugs always seemed to help.It's not as hard to do as it sounds.
Old 02-26-2005, 10:36 PM
  #39
Flyer's Avatar
Why use a torwue wrench for changing spark plugs?
  #40
Keith's Avatar
why???
Steel bodied plugs in an aluminum head. Heat cycling will make 'em really happy where they are. Just for ease of removal.
Do you have head studs or aftermarket bolts? Or are you removing and replacing the stock torque to yield bolts every time you take the heads off?
Quick Reply: Which plug for Radix?
