Which plug for Radix?
#51
Cuz I AM a BADMOFO
Originally Posted by moregrip
Indexing refers to an old racer's trick whereby the spark plugs are installed so that the ground electrode is oriented to face the intake valve (usually) in an effort to "open up" the spark to the incoming air/fuel charge. This is accomplished by placing a washer underneath the spark plug's shoulder area (of a specified thickness) so that after properly torqueing the spark plug, the electrode would be pointed in the desired direction, usually towards the incoming air/fuel charge from the intake valve.
Some racers have discovered that certain engine configurations made more power with the spark plug pointed away from the air fuel mixture.
It is important to note that any power increase will be small, typically 1-2% of total engine output, and the proper indexing orientation can only be discovered after extensive engine dyno testing.
http://www.nightrider.com/biketech/h...s_indexing.htm
#52
Originally Posted by BADMOFO
Wow, that was a great explanation! Wonder where you heard that from?
#54
Originally Posted by Flyer
LOL
You get those heads back on yet?
Looks like I'll have to change them out today.
Brian: I'll get some bin files to you this week, especially if the plugs do not remedy anything.
#57
I would like a copy of your stock bin file too please. I need the shift points for a stock 6.0/80e. A RADIX'd bin would be nice too.
flyer@woracing.com
Thanks in advance!
flyer@woracing.com
Thanks in advance!
#59
Can you tell it runs better with those plugs? Which ones did you end up going with?
I'll send you a stock and my Radix'd bin files for sure
