Which plug for Radix?
Old 02-27-2005, 10:19 PM
  #51
Cuz I AM a BADMOFO
BADMOFO's Avatar
Originally Posted by moregrip
Indexing refers to an old racer's trick whereby the spark plugs are installed so that the ground electrode is oriented to face the intake valve (usually) in an effort to "open up" the spark to the incoming air/fuel charge. This is accomplished by placing a washer underneath the spark plug's shoulder area (of a specified thickness) so that after properly torqueing the spark plug, the electrode would be pointed in the desired direction, usually towards the incoming air/fuel charge from the intake valve.
Some racers have discovered that certain engine configurations made more power with the spark plug pointed away from the air fuel mixture.
It is important to note that any power increase will be small, typically 1-2% of total engine output, and the proper indexing orientation can only be discovered after extensive engine dyno testing.
Wow, that was a great explanation! Wonder where you heard that from?
http://www.nightrider.com/biketech/h...s_indexing.htm
Old 02-27-2005, 10:44 PM
  #52
what a rush!
moregrip's Avatar
didn't I quote that?
Old 02-27-2005, 10:51 PM
  #53
Flyer's Avatar
LOL
You get those heads back on yet?
Old 02-28-2005, 09:07 AM
  #54
what a rush!
moregrip's Avatar
Originally Posted by Flyer
LOL
I didn't even get a chance to change my plugs, the wife had some friends over for an Oscar dinner and I helped prep a little. NakedAV stopped by and checked the gap on his plugs.
Looks like I'll have to change them out today.
Brian: I'll get some bin files to you this week, especially if the plugs do not remedy anything.
Old 02-28-2005, 08:37 PM
  #55
what a rush!
moregrip's Avatar
OK, just finished installing the TR6's gapped at .035, going for a test drive and a workout
Old 02-28-2005, 10:21 PM
  #56
what a rush!
moregrip's Avatar
seems better now, the acid test will be tomorrow when I try and start it in the morning.
Old 02-28-2005, 10:35 PM
  #57
Flyer's Avatar
I would like a copy of your stock bin file too please. I need the shift points for a stock 6.0/80e. A RADIX'd bin would be nice too.
flyer@woracing.com
Thanks in advance!
  #58
Flyer's Avatar
Can you tell it runs better with those plugs? Which ones did you end up going with?
Old 02-28-2005, 10:44 PM
  #59
what a rush!
moregrip's Avatar
I feel like it does run better, if that makes any sense, seemed to rev quicker, I went with the TR6's gapped at .035......next time I'm taking out a fender well, on a HD it's a far reach down to those plugs.
I'll send you a stock and my Radix'd bin files for sure
twake_410
04-14-2016 09:58 PM
00loudchevy
12-03-2015 05:54 PM
bearden86
26
11-15-2015 03:58 PM
02AWDAWSDenali
10-01-2015 05:08 PM
KleanKustoms
09-30-2015 05:07 PM
Quick Reply: Which plug for Radix?
