Plug wire recommendations
#26
FormerVendor
Originally Posted by w41quad4
I upgraded wires due to a slight miss I picked up, so when i put in new plugs I threw on some Crane wires, well they suck ***, 2 fell apart while driving, truck actually ran pretty decent and still idled running on 6 cylinders. Anyway I put in the MSD's and everything is perfect, the Crane wires themselves also helped the miss go away they just sucked.
#27
Whats the deal with those Nology wires? You have to use a ground plate or something? Didnt know if any of you had used them. Wanted to see how the install looked! I found some strong claims by some top magazines an they better for $250-LMAO!. Check it out!
http://www.eautoworks.com/html/produ...32529&reff=SMX
#29
in the FWIW catagory, there are two different length wires. One is for the Delphi coil packs (the round ones) and the other is for the square coil packs which if I remember correctly are Denso but don't hold me to the square pack manufacturer
rojeho
08-08-2015 07:20 PM
sauldgold
07-23-2015 02:15 PM
bsgiffor
07-19-2015 11:14 AM
