Which plug wires?
Which plug wires?
My stock wires are pulling out of the metal clip thing that connects to the sparkplug, and I have to recrimp it every time, these things need to go.
Which plugs wires are the best quality and fit? I also have ASM headers.
MSDs 8.5? Taylors 8mm? Or Taylor 10mm wires?
thanks.
thanks.
I cannot recommend TV50's.
My first set - I had some performance problems. Pulled the wires, and two to three of them broke at the spark-plug end. The clip stayed on the plug, and it pulled the end of the internal wire off.
I got another set under waranty. I went to put in spark plugs a little while back. I had another plug wire let go the same way.
I also noticed at the coil end - some wires get a good connection, others don't. The reason is that some of the wires have the metal clip about 3/8" from the end of the boot, while others have it about 3/4" back, so the "snout" of the coil "bottoms out" in the boot before a nice positive CLICK is heard from the clip.
I had a set of MSD 8.5's, and like them a lot... except for the fact that they were too long for my old 5.3 motor. They were the "LS1 truck" set.
I orderd a set of MSD's to replace my TV50's, and I went with the "LS1 car" set. They should be here this week.
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by marc_w
Cool... you should like them a lot.
I also heard that the factory metal heat shrowds can be used on the MSD wires, in case you have any heat problems from headers.
Tydriver
45
10-23-2015 09:19 PM
SlvrSierra4.8
10-01-2015 09:39 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
