popping/dying when accelerating
Old 08-29-2008, 10:55 AM
dlt76028's Avatar
Default popping/dying when accelerating
lately when my truck idles for more then 4 mins and i go to take off it wont go and i floor it and it says like 200rpms then it pops a few times and dies and wont start back up for a few minutes? no codes or lights. i recently put stock manifolds and cats back on... bad o2 sensor?
Old 08-30-2008, 07:35 PM
dlt76028's Avatar
any ideas before i go buy another o2 sensor?
Old 08-30-2008, 08:26 PM
hirdlej's Avatar
Your problem definatly sounds fuel related.......... Do you have access to any scanning software by chance?
Old 08-30-2008, 08:39 PM
Where's the Beef?
viciousknid's Avatar
By the looks of your sig i'd guess you have efi live? i recently had an o2 go bad and it would just miss like a bitch. BLACKGMC showed me a way to test them.
If you go to scan tool. Dashboard B, watch your HO2S11 (bank 1) and HO2S21 (bankt 2). they should both move up and down like a wave across the graph. If one stays constant it's bad.
But what your describing doesn't sound o2 related to me.
Old 08-30-2008, 09:10 PM
dlt76028's Avatar
yea i should be going to coreys(blackgmc) soon to log my truck with efi
Old 08-31-2008, 07:11 AM
Grumpy5.3's Avatar
when is the last time you replaced your fuel filter...
Old 08-31-2008, 11:16 AM
dlt76028's Avatar
maybe 7 months ago... but it did throw a code p0131 for drivers side o2 and i cleared it and it hasn't came back on but its still dying though
Old 08-31-2008, 05:24 PM
dlt76028's Avatar
did some logging today and my fuel trims were maxed at 25 on both banks but we checked everywhere and found no leaks also the o2 sensors were working fine while driving then after about an hour we were idleing and the o2s just flat lined and the truck started stuttering again. so im buying 2 new o2s
Old 08-31-2008, 08:16 PM
Where's the Beef?
check NAPA.
I got a Bosch o2 sensor at my local napa for $47
Old 08-31-2008, 10:49 PM
hirdlej's Avatar
If both your trims are maxed you have to think of the something that pertains to the whole engine. Things I'd be checking are fuel pressure, intake manifold gasket leaks or intake tube leaking after the MAF somewhere. It's going to be an air leak or not proper fuel pressure. If your trims are maxed positively, that means you're extremely lean. (positive trims means it's trying to add fuel).
Quick Reply: popping/dying when accelerating
