popping/dying when accelerating
#21
#22
your truck is rich. to have fuel trims like you do you need to lean out the motor. if you went from headers to manifolds then you are rich. when you go from manifolds to headers you run lean. its just the opposite
have someone play with your VE table for little bit of time and be done
popping and sputtering is direct relation of overly rich
#24
now are your 02s reading correctly? if they are resposive like normal and reading exceesive values of fuel trims then i would still play with VE till numbers came in order. but make sure you save each file as you do this so you dont get to far out of order incase this doesnt help any
#25
well if you are overly rich then adding fuel wont help. now if you removed fuel from a table that is too rich after you added fuel to it then your not improving.
#28
you need to keep this truck on a scanner till you figure this issue out or else you might hurt it. a scanner will tell you if 02s are working, fuel is rich or lean, and tell you if pump might be failing
#30
