ported maf ends? what happens when used?
What problems are there on trucks when descreening and porting mafs?
Can u attach it right up against air filter lid, so there is no turn of air into maf?
I would think doing this would fix any metering problems with modded maf?
There's no need to port a 85mm truck MAF,the ported ends are for a an F-body that uses a smaller MAF,descreening your MAF tends to lean out fuel mixtures which sometimes increases performance on a stock truck.Your best bet is to leave the screen alone.
I think it would give you those resuts. Problems lies in how much to port. Maybe you can take small steps and log the results as you go. Log it as is, then without screen, then with minor porting. Of course if you ever do any tuning you'll need to compensate for the modded MAF.
slowmo934
09-09-2015 01:24 PM
Fast86z
08-23-2015 01:35 AM
HectorM52
08-18-2015 01:40 PM
rojeho
08-08-2015 08:20 PM
