Ported throttle body question
#33
no one is saying there aren't gains to be had. What is being said is that the gains will be minimal at best until you open up the smallest area, and the risk of screwing something up is pretty high.
Head porting relies on completely different principles, combined with port volume. A smooth straight flow path is probably the most important thing, but requires volume to really be effective. And not just straight volume, port shape for velocity is important as well. There is no comparison b/t head porting and TB porting.
#35
IIRC trumm did a back to back dyno comparo a few years ago and gained a few hp from a p&p throttle body but lost one or two lb/ft of torque. Nothing substantial thpugh. If you can do it cheaply or even free, and it results in better throttle response, then it's worth it IMO.
#37
I think you are missing the point again. Until you open up the actual ID of the TB and increase the size of the opening you are not going to see much if any gain. What you are actually doing is "smoothing" the air path, this will improve the way the TB "processes" the air...but not how much air it will take in. What are you doing when you CNC a set of heads? OPENING UP THE INTAKE AREA! You are NOT taking in any more air until you OPEN up the effective throttle area. Anything else is snake oil and will be a negligible gain at best.
But hey, I am an idiot.
What are you talking about.... how the "TB processes the air"? The TB doesn't process any air.
So before you spread inaccurate information maybe you should understand WHAT IS BEING PORTED in the first place.
#38
Ok just installed my Shanner ported cable throttlebody and took it around the block. I definatly noticed a difference! I'm sure it has to do with the fact that my old was dirty as **** and it has the bumpstop carved out, but never the less I bolted it on and( I k ow this isn't even 90% accurate), accordng to my I phone app my before time was 13.3 quarter now it says 12.6 no I'm going to go on a limb here and say it gave me .3 sec improvment. This is ONLY a guess. It definatly was faster from the seat of my pants!!! I would definatly recomsnd a SHANNER tb!!!
#39
#40
