Is it possible? 5.3 with 315 WHP.
Is it possible to achieve those numbers with a 2007 gen IV LMG 5.3 with 243 heads, 1-3/4" Arh Headers, Airaid Jr. Kit, comp cams 212/218 114 LSA cam, Blackbear Tune, 4.30 gears and 31.5" tires.
My buddy says it cant be done with those mods only. He says i wont break the 300hp mark.
Formerly ScreamingL
Just dyno'd my jeep
It has a 2001 5.3 in it rides on 35x12.5x15s
Mods are gmt900 intake, baby thumper cam and true dual 2.5"
This combo was dyno'd on a mustang Dyno and made
Pulls were made in 3rd instead of 4th (cause of tire speed)
292/306
So yes a newer 5.3 with more compression and better heads on a Dyno jet will read higher
292/306
Thanks for the responses. My goal was to hit at least 300WHP on a mustang dyno. I would have went with a larger cam with a stall but i do tow 6500-7000lbs. I have yet to do the cam install. Im getting all the parts ordered now. 212/218 114lsa cam, dod delete kit, ls2 timing chain, correct cam sprocket, ls6 valve springs, complete engine gasket and seal kit including valve seals.
We have a $100 dollar bet that i wont hit 300hp. But we shall see. By the looks of it im seeing people around 300-320whp with a close setup to mine.
