Possible Fuel Pressure Regulator Issue?
Starting a thread because I can't seem to get the search button to work. Is a fuel pressure regulator on an 04+ in the tank as part of the fuel pump assembly? I'm noticing right at start up my turck smells like it's running rich. Don't have a wideband on it so I don't have any numbers. Tomorrow I'm going to check for vacuum leaks and fuel pressure. Anything else I should check?
You shouldn't need to replace anything. they all run rich at start up. Its normal. I wouldn't worry about it. If a regulator was going out your truck would either run like crap or not run at all.
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
