Post up your Shift Extensions...
Old 10-10-2009, 01:22 AM
  #21
9 Second Truck Club
stock48's Avatar
My pro yank 3400 drops to 4950~5K on a 5500RPM shift point both 1st, and 2nd. Thats with 14psi, 4L80E in 4wd.
Old 10-10-2009, 04:43 AM
  #22
Where's the Beef?
viciousknid's Avatar
Circle D 2800-3200 base converter:
1-2 6200 > 4800
2-3 6200 > 4600
That was with 4.11's 275/45/20 . Have to check the 4.30's and see it's the same or not.
May also need to bump my shifts up a little after reading this thread.
Old 10-10-2009, 07:15 AM
  #23
Wearin' da big hat
00ChevyScott's Avatar
I shifted that cam out at 6600 with the tow haul josh. It seemed to work pretty good.
Old 10-10-2009, 11:26 AM
  #24
TXsilverado's Avatar
Originally Posted by BlackGMC
I was just curious to see what other members shift extensions are?
I have a Performanbuilt 9.5 TC, that was supposed to be a 2800, but it acts more like a 3600... Anyways here are my shift extensions....
1->2
Shift at 6700 drops to 4850
2->3
Shift at 6800 drops to 5050
shifting 6750 it dropps back to 5200ish...new converter is supposed to keep me above 5500 at all times
Old 10-10-2009, 02:15 PM
  #25
ap2002's Avatar
Shift 6700, > 5000,
ive road in a truck with a circle D 4k, shift at 6800> 5900!!! it feels damn good
Old 10-10-2009, 04:23 PM
  #26
StrokerAce03's Avatar
Originally Posted by dlt76028
how is that ss3600 dd? what can you brake stall it to?
Its a great DD stall if you tune the lockup; I can get around kind of easy shifting at 2100 or so. It usually shifts between 2500-3000 with me driving a little lead-footed.
On good tires I can brake stall it to 2600 or so and it flashes to around 3400-3500 behind my bolt on 4.8.
Old 10-10-2009, 05:04 PM
  #27
04SilveradoMykk's Avatar
Here's my shift tables:
I don't use RPM because I have a 4x crank position reluctor wheel and a PCM looking for a 3x signal. I use MPH instead, with my tire & gear combo & drivetrain slip it's shifts around 5800-5900rpm
Old 10-10-2009, 11:05 PM
  #28
53RUSSELL's Avatar
4l80E w/stock stall cut to 2500
9-1/2lb of boost
1->2
Shift at 6000 drops to 4100
2->3
Shift at 6000 drops to 4300
Old 10-10-2009, 11:15 PM
  #29
2nd fastest 5.3 ECSB
trever1t's Avatar
ok, looking at a log that i just ran it shows me shifting a little earlier than commanded (6200) shifting from 6100-4600 in both the 1-2 and 2-3. Yank SC2800 converter.
Old 10-13-2009, 10:06 PM
  #30
nonnieselman's Avatar
6psi stock 80E converter
1-2 5500 - 3750
still lookin thru logs, but nitrous wakes it up.. just cant find the log.. argh..
Quick Reply: Post up your Shift Extensions...
